Discussion in "Map Me Support" started by    LondonGman    Aug 17, 2009.
Mon Dec 21 2009, 06:55 pm
soooo... i've downloaded mapme v1.3 from your homepage-downloads and installed this version. the user location update in this version works without problem - so there must be a difference between the verison posted from you in this thread and the one stored in your homepage-downloads...
Wed Dec 23 2009, 05:55 pm
yes, but it was a small beta coz i need people to test it. Now that you have confirmed the working of plugin i can upload it to e107 plugin site
is there anything which need to be added? but again volunteers needed to test I alone cannot do that.
Wed Dec 23 2009, 07:40 pm
why uploading? the working version is allready in your download section...
two problems exists still....
1) map doesn't shown in IE7 & IE8 (only see the message "loading")
2) map-zoom-setting and map start position (lat and long) did not work - the plugin/map ignore the values in plugin-settings
Fri Dec 25 2009, 03:29 am
well for some users the old version create problem, for the reason, people put whatever they want in their location area so sometimes values are not properly parsed in xml. so plugin actually needs an update for them
Mon Nov 28 2016, 02:16 pm
Hi there,
long time ago... i've a short question to you - e107v2 bootstrap is long time out and your plugin isn't compatible... is there a chance you'll upgrade your plugin for use with latest e107v2?
Tue Dec 13 2016, 02:21 pm
Hi Centurio,
I do not have enough time to update plugin to v2. I have not updated my website yet to v2... so you can imagine. The gmap code is very old and lot of things have changed now. So plugin needs to be updated. Hope someone will take time and do it for you maybe? I am really sorry for now.
Andyhet
Sat May 18 2024, 07:28 am
BrettTibre
Fri May 17 2024, 06:14 pm
Gordonfax
Fri May 17 2024, 10:28 am
Davidspils
Fri May 17 2024, 10:19 am
Patricknoind
Fri May 17 2024, 09:53 am
JeremyCycle
Fri May 17 2024, 09:46 am
FrabSeby
Thu May 16 2024, 07:31 pm
PeterGem
Thu May 16 2024, 06:27 am
