Discussion in "ARM Development" started by    nattu    Jul 24, 2008.
Tue Jul 29 2008, 02:22 pm
How to interface LPC2106 with L293D
make use of any two available gpios.
are u using PWM in IRQ maode??
Tue Jul 29 2008, 04:10 pm
Hi every body
I required some programming help. I am using LPC2106 for my project
Can you provide one example program for generation of 60% duty cycle PWM wave using keil ‘c’?
How to configure the PWM registers, how to find out match register value
I am using 14.7C61Mhz crystal & not using PLL
Thank you
Regards
chandu
Tue Jul 29 2008, 07:44 pm
[Thread moved to ARM Development]
Tue Jul 29 2008, 10:47 pm
hope u have a fair understanding of timers in LPC21xx controllers.. it is important for the PWM to be produced..
here take a look of this sample code based on 214x controller hope it helps ..
#include "LPC214x.h"                        /* LPC21xx definitions */
#include "type.h"
#include "irq.h"
#include "timer.h"
#include "pwm.h"
volatile DWORD match_counter;
** Function name:		PWMHandler
** Descriptions:		PWM interrupt handler
**				For now, it only deals with PWM match 0
** parameters:			None
** Returned value:		None
// mthomas: +static
static void PWMHandler (void) __irq
    DWORD regVal;
    regVal = PWMIR;
    IENABLE;			/* handles nested interrupt */
    if ( regVal & MR0_INT )
	match_counter++;
    PWMIR |= regVal;		/* clear interrupt flag on match 0 */
    IDISABLE;
    VICVectAddr = 0;		/* Acknowledge Interrupt */
** Function name:		PWM_Init
** Descriptions:		PWM initialization, setup all GPIOs to PWM0~6,
**				reset counter, all latches are enabled, interrupt
**				on PWMMR0, install PWM interrupt to the VIC table.
** parameters:			Duty cycle
** Returned value:		true or fase, if VIC table is full, return false
DWORD PWM_Init( DWORD cycle )
    match_counter = 0;
    PINSEL0 = 0x000A800A;	/* set GPIOs for all PWMs */
    PINSEL1 = 0x00000400;
    PWMTCR = TCR_RESET;		/* Counter Reset */
    PWMPR = 0x00;		/* count frequency:Fpclk */
    PWMMCR = PWMMR0I | PWMMR0R;	/* interrupt on PWMMR0, reset on PWMMR0, reset
				TC if PWM0 matches */
    PWMMR0 = cycle;		/* set PWM cycle */
    PWMMR1 = cycle * 5/6;
    PWMMR2 = cycle * 2/3;
    PWMMR3 = cycle * 1/2;
    PWMMR4 = cycle * 1/3;
    PWMMR5 = cycle * 1/6;
    /* all PWM latch enabled */
    PWMLER = LER0_EN | LER1_EN | LER2_EN | LER3_EN | LER4_EN | LER5_EN | LER6_EN;
    if ( install_irq( PWM0_INT, (void *)PWMHandler ) == FALSE )
	return (FALSE);
    return (TRUE);
** Function name:		PWM_Set
** Descriptions:		PWM cycle setup
** parameters:			PWM cycle and offset
void PWM_Set( DWORD cycle, DWORD offset )
    PWMMR1 = cycle * 5/6 + offset;
    PWMMR2 = cycle * 2/3 + offset;
    PWMMR3 = cycle * 1/2 + offset;
    PWMMR4 = cycle * 1/3 + offset;
    PWMMR5 = cycle * 1/6 + offset;
    /* The LER will be cleared when the Match 0 takes place, in order to
    load and execute the new value of match registers, all the PWMLERs need to
    reloaded. all PWM latch enabled */
    return;
** Function name:		PWM_Start
** Descriptions:		Enable PWM by setting the PCR, PTCR registers
** parameters:			None
void PWM_Start( void )
    /* All single edge, all enable */
    PWMPCR = PWMENA1 | PWMENA2 | PWMENA3 | PWMENA4 | PWMENA5 | PWMENA6;
    PWMTCR = TCR_CNT_EN | TCR_PWM_EN;	/* counter enable, PWM enable */
    return;
** Function name:		PWM_Stop
** Descriptions:		Stop all PWM channels
** parameters:			None
void PWM_Stop( void )
    PWMPCR = 0;
    PWMTCR = 0x00;		/* Stop all PWMs */
    return;
Fri Aug 01 2008, 10:04 am
Hi Ajay
I am very sorry for creation of one more thread
I have not seen my thread in the “Project Help forum”, that’s why I have posted one more thread to the project help
After your reply I got my thread in the "ARM Development forum” now I will continue same thread
Thank you
Regards
chandu
Fri Aug 01 2008, 09:20 pm
you are welcome nattu enjoy!
 nattu like this.
Sat Aug 02 2008, 04:39 pm
Hay
What are the default settings for CLOCK in the LPC2106? I am using 14.7C64MHZ crystal
With out PLL & VPB Divider can I write programs, can I use 14.7MHZ crystal directly?
If i have not did any setting s in the LPC2106, then what is default clock
Thank you
Regards
chandu
Mon Aug 04 2008, 10:55 pm
the above picture shows how it is...
i would really like to know why you are against using PLL .
Pll and MAM increase the fuctionality of arm tremendously.
still if not using arm .. just use the external crystal.. and the clock will be same as in any controller . in your case 14.745Mhz.
if not using pll i wud suggest u to go for a crystall anywhere from 10-30Mhz.. but choose a round figure equation say 20Mhz. rather than 14.745
that will make your calculations easier.
 nattu like this.
Fri Aug 08 2008, 10:23 am
hay
my circuit is generating 1KHz PWM pulses using LPC2106 micro controller My software is working well
I required some hardware help
I am planning to use L298 H Bridge Driver for my application, it have current sensing pins.
Please suggest switching optoisolater to isolate the LPC2106 with driver circuit & what hardware precautions I have to take to minimize the noise
Reagrds
chandu
Fri Aug 08 2008, 01:00 pm
try MCT2E or 4N32 opto coupler (single isolation), or MCT6E (2 isolators).
