Lpc2148 and Max3421 reset
Thu May 14 2009, 07:33 pm
so this means... data is not coming from slave side..
are you sure that it's being stuck there only? i mean how to make sure that this is the problem.
also are you giving some kind of delay? after reset or during reset?
Thu May 14 2009, 08:18 pm
i'm doing delay at the beginning of the vUSBTask, and after some SPI Write... The source i gzipped and attached is how i modified the source of maxim: i didn't use its initialization -> init_PLL() and init_IO(), because i have that functions already working specifically for the microcontroller.
My most fear is that the code of the SPI isn't working, and i am not talking to the pin chip select of the usb that is the P1.20
Could you control that part in my source please ?
thank you
thank you
Thu May 14 2009, 08:47 pm
damn... i have to go now... i hope we can talk tomorrow...
thank you
bye
Vito
thank you
bye
Vito
Fri May 15 2009, 01:12 pm
Hi,
i'd like to know if you think the SPI part is ok.
i know is a bad thing to ask.. but i don't have the necessary experience to know for sure about it.
thank you..
thank you..
Fri May 15 2009, 01:43 pm
i have to go through your code, but today some problem with server.. i seems to be busy with it..
Fri May 15 2009, 02:57 pm
oh... np... don't worry about it... you just did a lot anyway
just for the update...
i discovered that the command that should issue the reset to the host by the SPI... well it doesn't work...
so .... i guess.. that my thought about the SPI is more and more toward truth
but i need to investigate more to be sure about that...
c u soon
c u soon
Fri May 15 2009, 10:48 pm
What is the state of reset pin of MAX3421? You won't get OSCOKIRQ if device is being held in reset and that what I think is happening. To check if SPI is functioning, try to read REVISION register. You should get 0x12 if your MAX3421 is relatively fresh.
Mon May 18 2009, 05:23 pm
can you paste the terminal o/p of the following part of code:
coz after this your program gets halted right?
printf("First 8 bytes of Device Descriptor "); HR = CTL_Read(Get_Descriptor_Device); // Get device descriptor into XfrData[] if(print_err(HR)) return; // print_error() does nothing if HRSL=0, returns the 4-bit HRSL. printf("(%u/%u NAKS)\n\r",IN_nak_count,HS_nak_count); // Show NAK count for data stage/status stage maxPacketSize = XfrData[7]; for (ix=0; ix<last_transfer_size;ix++) printf("%02X ",(BYTE*)XfrData[ix]); printf("\n\r"); printf("EP0 maxPacketSize is %02u bytes\n\r",maxPacketSize); // Issue another USB bus reset printf("Issuing USB bus reset\n\r");
Tue May 19 2009, 12:56 pm
hi all..
i was back just today on this damn usb... well
Rickey it''s not that part that locks, i can't get to run the program until the part you're showing.... the reset locks just in its function call, that is firstly called in the main function:
the critical while, then is this:
@felis: tnx man, i'll try to issue this command to see if the SPI works, the maxim i have are just fresh, 'coz i got them just two weeks ago.
thanks to all of you for your precious help
void Reset_Host(void) { Hwreg(rUSBCTL,bmCHIPRES); // chip reset This stops the oscillator Hwreg(rUSBCTL,0x00); // remove the reset while(!(Hrreg(rUSBIRQ) & bmOSCOKIRQ)) ; // hang until the PLL stabilizes }
Tue May 19 2009, 01:23 pm
Ok Boys..... it is official.... i can't get the SPI working....
this is the source i use:
that was my main function....
and this is what i get on the serial output trying to read the revision number:
and that's all...... now i can't get why the SPI won't work.....
void main_func(){ wait_ms(1000); SPIInit(); init_IO(); unsigned char revision; char stringy[50]; initialize_ARM_Interrupts(); uart0Puts("setting full duplex etc etc....\n\r"); Host_SPI_Write(rPINCTL,(bmFDUPSPI| bmHOST | bmPOSINT )); // MAX3421E: Full duplex mode, INTLEVEL=0, POSINT=1 for pos edge interrupt pin uart0Puts("done\n\r"); uart0Puts("trying to read revision number:\n\r"); revision = Host_SPI_Read(rRevision); sprintf(stringy,"Revision Number: %x\n\r",revision); uart0Puts(stringy); /**** the following function is where it locks..... but now we know that the SPI is not working ****/ Reset_Host(); // Jan07_2008: Moved Reset_Host after MAX3421 is put in full duplex mode uart0Puts("done\n\r"); Host_SPI_Write(rIOPINS1,0x00); // seven-segs off uart0Puts("done\n\r"); Host_SPI_Write(rIOPINS2,0x00); // and Vbus OFF (in case something already plugged in) uart0Puts("done\n\r"); uart0Puts("done\n\r"); wait_ms(200); // aspetta = waits VBUS_ON; while(1) { detect_device(); wait_ms(200); // Some devices require this enumerate_device(); wait_for_disconnect(); } }
init ARM interrupts.....Finita(done) setting full duplex etc etc.... done trying to read revision number: Revision Number: 0 critical part....(Reset_Host())
