Discussion in "Embedded GSM Development" started by    Alvanbert    Feb 11, 2012.
Thu Mar 01 2012, 11:58 pm
#31
yeah it receives them and can display them if i widen the loop to display ten messages.
Fri Mar 02 2012, 09:43 am
#32
Ok then its fine..
U can divide the msg in next line.Use 20X4 LCD so that entire msg will be displayed in one shot.
Fri Mar 02 2012, 05:53 pm
#33
Hi kiran. I have tried using the 20x4 lcd display but the problem with it is it skips the second and fourth line hence it still leaves out some text
[ Edited Fri Mar 02 2012, 06:24 pm ]
Fri Mar 02 2012, 05:56 pm
#34
if msg has >40 characters. As with the 40x2, it displays only on the first line and leaves out some text as well
[ Edited Fri Mar 02 2012, 06:25 pm ]
Fri Mar 02 2012, 06:00 pm
#35
I want the 20x4 or 40x2 display to display on all line the same message(at once) from top to bottom without leaving out some text. Thanx
[ Edited Fri Mar 02 2012, 06:26 pm ]
Fri Mar 02 2012, 06:03 pm
#36
And I had forgotten to ask, Is it possible to add a scrolling format to the message display where by ot scrolls from the last line upwards as other messages follow from below.
[ Edited Fri Mar 02 2012, 06:29 pm ]
Fri Mar 02 2012, 07:32 pm
#37
Yes u can scroll the msgs.
Can u show us the code how u are breaking the entire array and sending to LCD.
Fri Mar 02 2012, 09:37 pm
#38
attached below is my entire code.
		 #include <REGX52.H>
#define LCD P1
#define LCD_EN		0x80
#define LCD_RS		0x20
//LCD Commands
#define LCD_SETMODE		   0x04
#define LCD_SETVISIBLE	   0x08
#define LCD_SETFUNCTION	   0x28
#define LCD_SETDDADDR	   0x80
void delayms(unsigned char);
void delayus(unsigned char);
void lcd_init();
void lcd_reset();
void lcd_cmd (char);
void lcd_data(unsigned char);
void lcd_str (unsigned char *);
void clear(void);
void tx0(unsigned char);
void delay_sms (unsigned int);
void SMSString(char*text) ;
void init();
void read_text(unsigned char *);
unsigned int var,i,n;
unsigned char j,abc;
unsigned char idata msg1[150];
unsigned char rec_no[20];
unsigned char time_date[20];
void gsm_loop(unsigned int);
void serial () interrupt 4
msg1[abc]=SBUF;
abc++;
RI=0;
void main (void)
n=0x35;
gsm_loop(n);
delay_sms(2000);
void gsm_loop(unsigned int n)
  for(i=0x31;i<=n;i++)
  clear();
  init();
  lcd_init();
  var=i;
  SMSString("AT\r"); // AT commands to initialize gsm modem
  delay_sms(1000);
  SMSString( "ATe0\r"); // turn off echo
  delay_sms(1000);
  SMSString( "AT&W\r"); // save settings
  delay_sms(1000);
  SMSString( "AT+CMGF=1\r"); // select text mode for sms
  delay_sms(1000);
  SMSString( "AT+CNMI=2,1,0,0,0\r"); // notification of new sms
  delay_sms(1000);
  SMSString( "AT+CMGR=");   // AT command to read sms
  tx0(var);
  SMSString("\r");
  IE=0X90;   // Enable serial interrupt
  delay_sms(2000);
  read_text(msg1);		// read sms and store in buffer msg1
  delay_sms(2000);
  IE=0X00;       // Disable all interrupt
void init(void)
j=0;
abc=0;
TL1=0XFD; //9600 @ 11.0592
TH1=0xFD;
TMOD=0x20;
SCON=0x50;
TR1=1;
void SMSString(unsigned char* text) //function to send SMS using GSM modem
while (*text)
tx0(*text++);
void tx0(unsigned char x) //send data to serial port 0
EA=0;
SBUF=x;
while(TI==0);
TI=0;
EA=1;
void delay_sms (unsigned int count)
unsigned int i;                         // Keil v7.5a
    while(count) {
        i = 115;
                while(i>
0) i--;
        count--;
void read_text( unsigned char *msg)
unsigned char *temp;
temp=msg;
do
msg++;
while(*msg!='#');
msg++;
do
*temp++=*msg++;
while(*msg!='#');       // reaching at end of message
*temp='\0';
lcd_cmd(0x80);
lcd_str(msg1);
         // array having message
void lcd_reset()
	LCD = 0xFF;
	delay_sms(40);
	LCD = 0x03+LCD_EN;
	LCD = 0x03;
	delay_sms(40);
	LCD = 0x03+LCD_EN;
	LCD = 0x03;
	delay_sms(5);
	LCD = 0x03+LCD_EN;
	LCD = 0x03;
	delay_sms(5);
	LCD = 0x02+LCD_EN;
	LCD = 0x02;
	delay_sms(5);
void lcd_init ()
	lcd_reset();
	lcd_cmd(LCD_SETFUNCTION);                    // 4-bit mode - 1 line - 5x7 font.
	lcd_cmd(LCD_SETVISIBLE+0x04);                // Display no cursor - no blink.
	lcd_cmd(LCD_SETMODE+0x02);                   // Automatic Increment - No Display shift.
	lcd_cmd(LCD_SETDDADDR);                      // Address DDRAM with 0 offset 80h.
 void lcd_cmd (char cmd)
	LCD = ((cmd >
 4) & 0x0F)|LCD_EN;
	LCD = ((cmd >
 4) & 0x0F);
	LCD = (cmd & 0x0F)|LCD_EN;
	LCD = (cmd & 0x0F);
    delay_sms(1);
void lcd_data (unsigned char dat)
	LCD = (((dat >
 4) & 0x0F)|LCD_EN|LCD_RS);
	LCD = (((dat >
 4) & 0x0F)|LCD_RS);
	LCD = ((dat & 0x0F)|LCD_EN|LCD_RS);
	LCD = ((dat & 0x0F)|LCD_RS);
    delay_sms(1);
void clear(void)
unsigned char a;
for(a=0;a<100;a++)
msg1[a]=0x00;
void lcd_str (unsigned char *str)
	while(*str){
		lcd_data(*str++);
Fri Mar 02 2012, 09:39 pm
#39
The above code only displays messages enclosed between #. i wanted to include that option in my code
Fri Mar 09 2012, 09:56 pm
#40
Guys. Pliz really need your help
Michailqfh
Fri Mar 29 2024, 01:53 am
Bobbyerilar
Thu Mar 28 2024, 08:08 am
pb58
Thu Mar 28 2024, 05:54 am
Clarazkafup
Thu Mar 28 2024, 02:24 am
Walterkic
Thu Mar 28 2024, 01:19 am
Davidusawn
Wed Mar 27 2024, 08:30 pm
Richardsop
Tue Mar 26 2024, 10:33 pm
Stevencog
Tue Mar 26 2024, 04:26 pm
